![]() | Home > Technical > TDCi fuel system |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
It is a low pressure system from the tank to the pump where it then becomes a HP system to the rail.
Brian. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
Thank you for the quick reply.
where abouts is the pump located please? ie could i tee in prior to the pump so supply fuel to a DBH such as a Websato? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
The high pressure pump (installed on the engine closer to the brake vacuum pump) also have the feed pump. No external pump on Puma Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
so you can tee in one route from the tank to the pump or on its return then for a LP feed. ie could take it off the fuel cooler on the return? Cheers
Practically no! ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Personally I would not interrupt the fragile Low pressure fuel feed system by tapping into it. The safest option is to take a separate feed from the fuel tank or mount an auxiliary tank somewhere. On the Puma engine there is only the fuel pump eccentric cam to draw fuel through to the pump from the tank. There would probably be feed issues and fuel starvation to the webasto due to the syphon effect of the fuel pump, though you could probably put in a one way valve in the inlet side of webasto fuel intake to compensate for this though what issues this may cause to the fuel feed to the fuel pump is anyone's guess. Also it may give another issue in that it is somewhere else to leak from, lose pressure because off. Just my opinion, Brian. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
how did you fuel your webasto dgardel? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
jst - take a look in here:
http://www.defender2.net/forum/topic8509.html?highlight=webasto there's a whole section on installing the pickup in the fuel tank. Also do a search on Webasto there's loads of stuff about fuel lines. I looked at teeing off the fuel line but the general consensu was don't. |
cheers Guys,
i ran an extra pickup for the one in my Td5 from the tank, looks like if i fit one i will be doing the same again then. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Like on the link wrote by Cobs, I inserted the pick up un the fuel level sender flange Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
that's the baby:
Webasto low profile diesel pick-up pipe (Webasto part no: 41S45017A) |
whats in dropping a puma 110 tank? same as a td5 110..
This is mine solution. Photos are taken from internet, not my car mod. I'll take same from my car soon.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
