Home > For Sale & Wanted > [For Sale] 4.6L Rover V8 Engine - NOS |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
Due to a change in direction for my 127 project, I have for sale a brand new, 4.6L Rover V8.
The engine has been dry stored, lubricated and periodically turned over but has never been run. The heads are new and have been flowed by Roland at ACR but are otherwise stock. The block is a red coded block, benefiting from the thicker cylinder walls. It is crossbolted, and fitted with new 4.6 crank, pistons etc etc. For sale in long block configuration with a choice of cams; a genuine, long nose (14CUX) cam or a Piper 270 GEMS cam - £3995 More than happy to provide photos, but it looks much like a new engine really! N.B. Engine us currently in short block configuration following the work to the heads, but can be reassembled if preferred. Also for sale by seperate negotiation, sufficient parts to build the engine up in either 14CUX or GEMS configuration, most of which are new OEM or genuine refurbished. Should it be of interest, I will also be listing for sale an essentially brand new, V8 spec, Suffix L R380 Gearbox with uprated rear support bearings and all new OEM gears, synchros and bearings in a refurbished casing. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
28th May 2023 11:26am |
