Home > My Defender > 1989 Ninety CSW - Update: 8 cylinders |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 507 |
Actually not Procta - this one was completely opportune. It was parked up in a village I've never parked it in before, 2hrs later it was gone, makes it even more unbelievable really.
I've notified my insurance of the incident but not claiming as not worth it with excess and losing NCB etc. Will figure out how to get it home once it's released from the police compound and inspect the damage in more detail. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
23rd May 2023 8:16am |
Got the car back now, predictable damage to the ignition barrel, steering column surround and brake pedal. Some additional damage to some wiring looms as no power to radio and charging ports etc
The more surprising/concerning discovery was a small dent/scuff in the front diff casing and a chip in the paint on the front offside wheel rim with hefty scuff marks in the tyre so it seems like it's had a couple of whacks in it's stolen journey Only found these marks while investigating a new squeal on that same wheel which sounds distinctly like an unhappy wheel bearing presumably as a result of that whack. Click image to enlarge Click image to enlarge Will take it off the road for a bit now while I strip that hub down and give everything else a good check over and then figure out what I do next... I can't deny the whole ordeal has taken a lot of the pleasure out of owning the car and I'm going to need to take some time to think about what I want to do with it now Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
27th May 2023 8:34pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 204 |
Sad news, but really glad you've got her home.
I wonder if the damage to the wheel and axle are a result of them cutting the brake pedal and using a kerb or something to slow them down? Did the forensics manage to find anything? Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
27th May 2023 9:47pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5215 |
from the looks of that, it sounds like they just stole it to feed they little jollies, Like they did with mine. Please do not be disheartened about what's happened, After all you have blew a lot of time and hard work into rebuilding this into that Landy you wanted. I lost one, and i have come back a lot stronger. Also i know what its like to lose pleasure out of a project too, to the point i nearly chucked it all in. 12 years ago me and my dad did something very similar, but dropped a VVC engine into a rover metro, We had did some extensive welding to the body, and i had to replace the full cars electrical system and salvage parts from scrappies, and fork out a on donor car and an engine. We had put it all together, and my parents had gone a way on holiday, i managed to buy the last piece of the puzzle and that was £200 on a recore on a radiator. Anyway not long after the system was bled through, and i did some final touches etc. The engine died on me on tick over, turned out i was sold a bad one, that had the headgasket failure, and the head was tightened down to hide it, to the point they had damaged the vvc pickup ( £500 part) and chewed a head bolt, making the engine worthless to sort out. VVC engine was the same price as a VVC pickup cam. Me and my dad were that winded after all that, he just sat watching TV in disgust, i was highly wound up. I was practically on the verge of just saying to my dad sod it, drag it to the scrapyard and weigh it in. When i told the forum i was on, what had happened. Not one of them said Procta chuck the car etc. They said you have got this far with it and we have followed you with this, so you cannot back out of it now!! The lad who helped me diagnose it, managed to sort me out a replacement engine. Which was more powerful unit, So with in a week. Me and my dad managed to pull the project back online. Took another year of putting it back on the road. But we made a belter of a car. After what happened did put me off the car, but as soon as it passed its MOT and road worthy, that went away. We enjoyed every bit of it, and laughs we had. So basically you will come back stronger, just put it down as bit of bad luck sadly like i did. with mine Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
27th May 2023 11:50pm |
Definitely a possibility but the scuff in the tyre doesn't look to be one of a wheel that was in rotating motion as it's a largely straight line towards the centre of the wheel and with such large tyres it would take a serious knock to get up to chipping the paint on the rim. Not heard anything from police re forensics but I don't hold out much hope - someone with this amount of experience stealing Land Rovers is not going to make the oversight of not wearing a pair of gloves... Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
28th May 2023 9:49am |
I am not surprised you wont hear anything back, They will have got what ever, and tossed it on a file. Build a case against who ever, it is. That's about it, 9 times out of 10 nothing goes any further.
As for the whack and scuff, Christ knows what they have hit, when they have had their little jolly. I recon they may not have twigged its a V8, and its been to fast for them to handle. How are you getting on sorting it out ? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
5th Jun 2023 6:54pm |
Been cracking on with it recently, semi-dismantled and prepping for paint.
Same colour, full Paintman suite of paints, not taking it all back to bare metal but sanding re spray off to factory paint and then priming, undercoating and coach enamel top coat. Been doing all the sanding by hand so fairly lengthy process but there’s no rush as I can’t paint in these temperatures at the minute anyway. Click image to enlarge I’m planning to do the whole job on the driveway, not really got any painting experience but taking my time and doing lots of research, hopefully it turns out half decent. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge And finally… an exciting crate from Exmoor! Was always the plan eventually and a fair saving in the Black Friday discount was enough to pull the trigger Click image to enlarge Click image to enlarge Hoping to get all the work tidied up and chucked on in time for some spring sun, I’ll be keeping this thread up to date with spraying progress Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
14th Jan 2024 7:09pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Thank you for the update and it's great to see you doing some work on the 90 and making good progress from what i can see in the pics
Will look forward to the updates as and when they come Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
15th Jan 2024 8:28pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Great work! Keep it up James
16th Jan 2024 4:27pm |
Great to see Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
21st Jan 2024 8:23pm |
Cheers all
Been plugging away at the prep/painting process as and when I can in the last few weeks. Finally got some paint on now, Paintman light grey primer followed by light blue undercoat. Pleased with how it’s gone on generally, seems to be a really good quality product and leaves a nice finish, also easy to work with as someone with minimal previous spraying experience. Have to say the undercoat is a much brighter colour than I was expecting, there will be a coat of hopefully less vibrant Arles blue going over the top! Click image to enlarge Click image to enlarge Had the gazebo out this weekend to start putting primer on the main vehicle bodywork, slightly sub-optimal setup with the sides flapping about but getting the job done nonetheless. Click image to enlarge Click image to enlarge Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
31st Mar 2024 8:48pm |
Great work!! James
31st Mar 2024 9:07pm |
that bonnet looks fantastic! Do a decent prep and your practically sorted really. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
1st Apr 2024 1:16am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3454 |
Looking great already 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
1st Apr 2024 5:16am |
