Home > Modifications & Maintenance (L663) > Anderson 175A connector in 'faux' Vent |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1056 |
Click image to enlarge |
10th May 2023 12:49pm |
DAP2022 Member Since: 16 Feb 2022 Location: Norfolk Posts: 119 |
do you have a cover? - could also use for battery charging?
10th May 2023 2:16pm |
does a grill cover this when not using lead?
10th May 2023 5:09pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1305 |
You're building a nice rig. It's got me thing about mine. I want to use mine as a base for gravel / mountain biking. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
10th May 2023 5:30pm |
I only fitted it today. Wasn't planning on fitting a grille, who knows. |
10th May 2023 5:55pm |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 71 |
If you prefer to solder a heat gun works well (two 120 watt soldering irons are not enough), use lead/tin solder. Tin only solder is a pain & has other issues.
175 to 50 amp adaptor. Click image to enlarge Visitor - Freelander owner |
21st May 2023 11:31am |
Plagiarism - from the Freelander Forum
23rd May 2023 11:10am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1762 |
No no nooooo. Just crimp them. Solder makes a stiff point in the cable that leaves it prone to cracking. A good crimp is a much better option for stranded cable. |
23rd May 2023 4:47pm |
Very true. Soldering can cause 'wicking' of solder down the insulator sleeving, which is prone to fracture. I did in fact crimp mine. |
23rd May 2023 6:58pm |
