![]() | Home > General & Technical (L663) > Scissor jack. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
It's a different system on the new Defender, my tyre guy gave me a couple of these things for my trolley jack
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Chris S Member Since: 22 May 2023 Location: Aberdeenshire Posts: 43 ![]() ![]() |
Thanks Ian.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2116 ![]() ![]() |
If lifting any vehicle on a seam seal jacking point then get some cheap ice hockey pucks and cut an appropriate slot in them. Cheap and very effective.
I use a router to cut slots but a saw and chisel can do the job if you do several saw cuts. You can also cut them to shape to fit on top of axle stands. |
