![]() | Home > Defender Celebration Series & Classic Works > In search of a softer ride on my Heritage 90. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3520 ![]() ![]() ![]() |
I replaced the rear springs which were dual rate on my CSW 90 to a single rate 150lb/in. I kept the original shocks. Although the ride firmness improved, as in became softer, I still find it a bit harsh. Putting about 90kg in the rear transforms it. I do think it has to do with the ratio of unsprung to sprung weight. The total weight at the rear is about 900kg, of which about 180kg is unsprung (axle, wheels, springs and shocks). So you still need heavy springs and shocks, otherwise the axle would start bouncing around and tyres loosing contact with the ground.
Lower tyre pressure help to soften the shocks from the unsprung weight. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
As per Dinnu, check tyre pressure. I ran my MTRs at 28. When I picked it up from the dealer they were at 40 and it was pretty much undrivable!
I should add, I had alive comfort springs and fox 2.0 shocks and it was a pleasure to drive. |
Nothing worse than an uncomfortable ride. I once accidentally stuck 130 rear shocks in to my old 90 and it was like riding on bricks. Replaced them with a pair of correctly valved 90 shocks and all was well again.
Do you have adjustable shocks? can you get the valving adjusted? What seats do you have fitted? How old are they? What bushes do you have fitted? How old are they? As above what pressures are your tyres at? How old are your tyres and how much tread is left? How much side wall do they have? If you have anything more than a 16" wheel you are sacrificing comfort for "sportiness"... ![]() Comfort in a Defender requires a layering of bits to reach that goal, including bushes, shocks, spring isolators, wheel and tyre choice, seat and constant payload. |
