![]() | Home > General & Technical (L663) > Defender 90 Signature Graphic Panel |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Have a look through PowerfulUK’s YouTube listing as they removed them from The Stig at one stage to see what it took and to develope the bits needed to blank the mounts for them. In my 1st Ed 110 I had a leak sourced to the small part on the rear panel - minimal sealant with gaps in the runs of the stuff were found to be the source. There are holes in the glass too as my new 90 was specced with privacy AND the Signature Square and both were missed off the build sheet either by the dealers admin or the factory and obtaining the right tinted glass to have the squares was an issue but solved, then the tailgate glass with privacy was on back order so I’ve had a refund on those items and have a 90 with plain glass all round and a set of roof crossbars and cash instead………
![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 ![]() ![]() |
I’d imagine they’ll be screw holes? 24MY 90 D250 HSE, Tasman Blue
AmL Member Since: 22 Jan 2016 Location: Devon Posts: 30 ![]() ![]() |
Thanks Tim, I've seen the PowerfulUK video for the 110 panel removal but can't find anything for the 90. I'd like to remove both the outer square panel and the internal storage rack (on a 90) but can't find anything which shows if there are holes in the glass/trim, or if both parts are just bonded to the glass. If just bonded, I'll do it but if also mechanical fixings, probably won't.
Looks like there’s two holes
![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 ![]() ![]() |
Not only holes..
![]() Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Thanks all. Was hoping I was only dealing with adhesive and removal would be straightforward but if there are holes in the glass, I’ll probably have to live with them.
IIRC PowerfulUK sells blanking pieces for the holes Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
