Home > Td5 > td5 head bolt sequence - really 5 step?
alexatnd
Hi,
Just tightening hread bolts after replacing hed gasket on my 10p TD5. So tightening sequence is
1) 30Nm
2). 65Nm
3). Tighten to 90deg
4). Tighten to 180 deg
5). Tighten to 45 deg
ok so ive done steps 1-4 and am at step 5
whimpering a bit do haveto make an effort turning the head bolts.
not bothered about the effort, more concerned about snappinhg the head bolts. Do I rteally have to do the last 45 deg?
What do other people do ?
Case of just get on with it or is 1-4 enough
Rgds
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #993321 19th May 2023 8:24pm
geobloke
Yes you must do all the steps. The head bolts are stretch bolts and need the incremental torquing down.
Post #993326 19th May 2023 9:00pm
A.Rubio
Spain
It is assumed that you have blown out the holes where the cylinder head bolts screw in, because if there is any oil left in them, this oil can cause the cylinder head to not fit well
Post #993382 20th May 2023 1:17pm
alexatnd
damn no i didnt, dodnt have any way of doing that Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #993408 20th May 2023 5:48pm
htb2
Wales
In that case a piece of wire with rag on bottom to soak up the oil, will have to suffice.
Post #993412 20th May 2023 6:05pm
NickMc
Take one of your old head bolts and cut some grooves lengthwise in it with and angle grinder and use it to clean the threads out. Lightly Oil your new bolts and under the heads of the new bolts and follow the full sequence as they’re Torque-to-Yield (TTY) bolts hence the degrees sequence on the td5.
Post #993448 21st May 2023 1:41am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Or an air line and blow it out. Or… brake cleaner and spray it in there then forceps with a bit of rag to dab up the remains.
Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #993449 21st May 2023 3:02am
