Home > Td5 > Electrical plug identification |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Third ones are for the EGR solenoids.
I dont recognise either of the other two as being original (at least on UK model). The round one looks very much like a block heater though. Steve 02' 110 TD5 Double Cab Rebuild Thread |
18th May 2023 6:44pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Top one goes in the bracket bolted on top of transfer box and plugs into the fly loom for either diff lock of high low ratio switch
Think block heater 2nd Last is for EGR on inner wing. |
18th May 2023 6:55pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 622 |
I' m also interested in the first one. Had found the same on 130 2006, and it is not hi/lo switch or difflock switch, both of these I have connected and working. I made a look through RAVE and found nothink. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
18th May 2023 7:31pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1052 |
If you can identify the wire colours you can trace back original wiring at the following link:
https://www.lrworkshop.com/connectors/defender-2002my/colour |
19th May 2023 4:32am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Wire colours are the best way to trace what wiring is, as connectors can be changed by previous owners due to damage etc. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
19th May 2023 6:37am |
I went through schematics also with wire colours, but not find anythink. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
20th May 2023 6:15am |
mrodey Member Since: 18 May 2023 Location: Svedala Posts: 30 |
Same here... I could not find any matching references
20th May 2023 6:07pm |
