![]() | Home > Maintenance & Modifications > Window Blocks |
You shouldn't have to remove the roll cage strut. The only thing I would do is fill up the rear void with silicone. It helps the gasket seat properly against the bulkhead and as such reduces the chances of water leaking past the gasket.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
When I refitted mine, I used standard paper gasket that I soaked in oil. I also applied some butyl around the bolt holes to ensure no water gets into the bulkhead.
I would not use silicone, as it has high content of acetic acid, which promotes corrosion. However filling with epoxy or similar is not a bad idea, if the offraod monkey ones are hollow like the genuine ones. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
