![]() | Home > Maintenance & Modifications > Bonnet pin |
Drevil Member Since: 03 Jan 2022 Location: Berkshire Posts: 134 ![]() ![]() |
Anyone know what size the lock nut on the bonnet pin on a Puma is?
Thanks |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17727 ![]() ![]() ![]() |
Do you mean spanner size or thread dimensions?
Good question….spanner size.
Sits in between two of mine and would rather not buy 3 guessing the size. Thanks |
OK, I'll measure mine later for you.
Thanks
I've just measured mine and according to Mr Mitutoyo's finest it is 32.19mm AF. A 32mm spanner, or at a pinch a 1.1/4" AF spanner, should do the job.
Be aware that there are two different pins used on late Defenders as I found out the expensive way when mine needed replacing (the bonnet kept popping open whilst driving, which is disturbing). I think the nut is the same however. |
Awesome thanks.
Remember the bonnet on one of my minis popping up on the motorway…..bit of a bum clencher! |
