Home > My Defender > 130 Camper Conversion |
mgokturk Member Since: 10 Mar 2023 Location: istanbul Posts: 4 |
Click image to enlarge Well thought setup. Did you ever need a passage between cab and the box? Such as in emergencies in certain places or in cold weather? To grab something from the back? I have almost the same setup with 110 box. Cannot decide whether to cut thtough the center windoe down to rear half bulkhead (just at the back of center console level) and make a metal suround from inside and outside. Like a space rocket attaching to space station What do you think? Is it worth it? |
2nd May 2023 8:16pm |
Ratty43 Member Since: 01 Sep 2021 Location: Cornwall Posts: 87 |
It's a good question and one we're still discussing! We don't have a crawl through, although it would be possible through the rear window as you say. The downside is that it opens up a good route for water ingress. There is the strong point of being able to get to the cab and drive off if in danger but to be honest with canvas sides around the bed and the faff of actually climbing out of the bed and through I'm not sure that I would get that far. Also, you have to consider the likelihood of such an issue occurring, everyone we have met so far (admittedly we've never been anywhere wild) has been very friendly. I read what I think is a really good but of advice - 'either camp in the middle of nowhere so nobody knows you are there or on the edge of a village so everyone knows you are there'. I'm planning on following that as a sensible path. Probably just massively tempted fate!
There are advantages to not having a link to the camper other than the risk of leaks, the main one being noise, friends with vans routinely complain about thinks bumping about. |
2nd May 2023 8:23pm |
One other thing to bear in mind is that the box will flex away from the cab so if you do go down this route look to use something flexible for the link.
Also meant to say - cracking 110 you have there! |
2nd May 2023 8:27pm |
thank you. will update about the result on another post, consulting with caravan builders and bodywork guys.
3rd May 2023 7:53am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 |
There's always up's n downs in any journey but i'm glad that you came through all good and what a journey you both had. Thanks for posting the trip Clayton.
17th May 2023 9:46pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Fab write up of the trip - very envious and getting itchy feet again !
Love the vehicle worked well for the trip and only ‘minor’ issues at the time ... well as you say its a 30yr old landrover and they are unique at any age ! looking forward to the next adventures! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
18th May 2023 7:41am |
