![]() | Home > Maintenance & Modifications > Handbrake stud removal? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17609 ![]() ![]() ![]() |
They're not studs, they're 3/8" UNF x 1.3/4" bolts, and the heads are prevented from rotation by the close fit of a land on the back of the flange. The bolts are retained by a large circlip fitted to the flange.
To replace: 1) Disconnect the front flange of the propshaft and tie the shaft out of the way (spanner size is 9/16" AF but a 14mm will fit). 2) Release handbrake (making sure that the vehicle is chocked, of course) and remove the drum. It may be necessary to slacken off the adjuster, but usually isn't. 3) Drain the oil from the transfer box. 4) Remove the retaining nut from the flange, remove the flange. 5) Remove the large circlip from the back of the flange followed by the four captive bolts. Reassembly is the reverse of the above, but don't forget to refill the transfer box with oil. Note that it is a good opportunity also to replace the rear oil seal if necessary. |
Ap077 Member Since: 19 Sep 2021 Location: York Posts: 24 ![]() ![]() |
Lovely stuff chap, thanks
