Home > Modifications & Maintenance (L663) > Another reverse light upgrade option |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6610 |
The first post does mention they have a ring of red LEDs (which the OP did not connect). 1988 90 Td5 NAS soft top
2015 D90 XS SW |
25th Apr 2023 5:14pm |
DaveCNB Member Since: 15 Mar 2022 Location: So. Cal Posts: 63 |
If these are the Hunter's ones you're referring to:
https://huntersprestige.com/collections/ne...erse-light Then yes, they appear to be the same aftermarket lights (even the packaging looks to be the same) just in the red surround variation. The ones I sourced on AliExpress were the black surround configuration (black colored plastic in the surround, but the surround does light up red if the wires are left in their stock configuration). I've seen examples of folks who have the black or red and surrounds working and disabled, they all look good in their own way and work well, just depends on your personal tastes. -------------------------------- "Chonky" 2024 Defender 110 X-Dynamic SE P400, Pangea Green, Air Suspension, Off Road Pack, Urban Pack (exposed recovery points), Factory Side Steps |
25th Apr 2023 6:37pm |
