![]() | Home > Puma (Tdci) > Slight missfire ? |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 506 ![]() ![]() |
Wise ones
So I changed my cylinder head temp sensor to get rid of the diesel clatter and it worked fine, the only thing now is that the car seems to have a very slight "missfire" at around 1500 rpm, it's barely there and just feels like more of a hesitation/slightly rough spot. So what do we think it may be?, I'm going to let the local landie guy have a look but any pointers from you lot would be gratefully accepted. I'm also open to the idea that she just drives a bit differently as I'm guessing that she is now fuelling differently thanks to the new sensor. Thanks Wes Oh woe, oh woe My crusty old landrover, It will not go. |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
Quick guess, is that when the turbo starts to boost? Could be a split turbo hose. The ECU would expect to see a ride in manifold pressure but the split would vent it and it'd have to recalculate which gives that little hiccup. There are two hoses, one going into the intercooler and one coming out to theanifold. Both relatively easy to prod and poke and look for splits.
Thanks for all the advice gents, managed to sort the slight juddder/misfire.
On a completely unrelated matter, check that your drivers side front wheel hasn’t lost its balance weights…… Oh woe, oh woe My crusty old landrover, It will not go. |
