Home > General & Technical (L663) > Front lower bumper end caps
LR Nuts
Does anyone have these lower bumper protection ? items fitted ????
Post #988597 11th Apr 2023 1:35pm
LR Nuts
So I got 98 'views' and NO replies. Are they rare ?
I decided to built my own, as I don't think they are available from JLR separately, only part of a kit ??
Mine are taller, higher fitting than the JLR units. They are secured with Large Head Torx Bolts.
Post #988716 12th Apr 2023 11:38am
XplusYplusZ
Not visible on my MY23.5 X-Dynamic pack with the gloss black lowers.
Which pack do they come in?
Post #988729 12th Apr 2023 1:14pm
Retroanaconda
Expedition protection pack or something like that wasn’t it? I seem to recall that it gave a higher clearance on each corner as well as extra protection.
Not very popular as it doesn’t really add very much to be honest, the approach angle is already very good.
Post #988735 12th Apr 2023 1:25pm
Defendit..
Netherlands
The idea of the raised corners is indeed better clearance.
I'am looking for them a long time, I'am a bit sick cleaning the mud between the rubber air deflectors and the corners.
https://www.defender2.net/forum/topic83517.html No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #988751 12th Apr 2023 3:55pm
LR Nuts
Yes, I'm not sure about the Rubber Spats, that sit beneath the Corners. These have an effect on water flying over the bonnet and onto the windscreen, of which the New Defender is bad at.
(I had experience of these type of Spats on an earlier project. JLR had two goes at getting them right, smaller Spats on earlier model got replaced by bigger Spats on later models.)
I will test as it is now, if needed I can always remove the Rubber Spats.
To get the effect I have ...... I simply acquired a set of Plastic Corners (from a breaker) and cut/model the shape I needed.
Post #988764 12th Apr 2023 5:54pm
LR Nuts
Retroanaconda wrote:
Expedition protection pack or something like that wasn’t it?........
.... that's the one Very Happy
Post #988951 14th Apr 2023 2:01pm
RobN
United States
Here are the official install instructions, if anyone cares to see just how much work is involved just to raise the corners by what looks to be no more than an inch.
https://accessories-instructions.landrover...r/G2409781
Post #989095 16th Apr 2023 4:42am
lightning
Wow that's a lot of work.
Not sure the small advantages of this kit are worth it, although the front bash plate would be worth fitting on its own.
Post #989198 17th Apr 2023 9:34am
