Home > General & Technical (L663) > Defender L663 overlanding review |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
Not sure you could fix a 2.2 Puma at the side of the road either!!
30th Mar 2023 6:57pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
I never felt at ease with our TDCI in Africa. Sure if it had lunched an injector or needed something ECU based we would have been flatbedding it across to Gib 1951 80" S1 2.0
1st Apr 2023 6:41am |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 145 |
This is exactly the reason we developed the IIDTool. The best 4x4xfar was limited to going places a tow truck could reach to bring it back to a main dealer. We (GAP Diagnostic) are nothing but a group of LR enthusiasts who went a bit overboard
I disagree on the repairability of older vehicles vs newer, btw. How many LR owners would be able to diagnose much less repair a fueling problem on a TD5? On a vehicle with proper diagnostics, it will tell you what is wrong. And these days that will even generally be correct. RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
11th Apr 2023 3:03pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2925 |
How many people have had a new Defender actually break down, so it can't be driven?
l've actually only heard of one. Sure, there's issues as with any complex vehicle but nothing that actually stops it from being driven. l've never actually had a modern vehicle let me down since my brand new Alfa Romeo broke down on the motorway back in 1998. Even that started again after 45 minutes (only to break down again at the dealership) |
11th Apr 2023 7:56pm |
The fewer there that break down are the better for all of us, no?
If I understood what you are saying correctly: the point is not if the vehicle is no longer moving or not, the point is being able to repair your LR anywhere with bailing wire and duct tape. Just like 50 years ago. Only now it's bailing wire, duct tape and a small, highly capable diagnostic tool. So you can go anywhere just like 50 years ago. RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
11th Apr 2023 8:46pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 161 |
It was a good article but Pat is a dyed in the wool old defender chap (nothing wrong with that).
BruceT on here has done numerous overland trips, have a look at his YouTube: @OverlandingwithBruce Also, Simon (PowerfulUK) did a video debunking ASPW's contention that the new Defender would grind to a halt if a sensor failed. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
11th Apr 2023 9:41pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
The only issue that I have come accross with the new style defender has been a flat battery which was from having the door open numerous times when parked up overnight while camping ... but was easily solved with a jump start ...
Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
12th Apr 2023 9:52am |
