Home > My Defender > 200tdi to M57 |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
Nice project! Did you change the engine mounts on the chassis or fabricated brackets to suit? 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
31st Mar 2023 7:43am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
Welded in engine and gearbox mounts. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
31st Mar 2023 2:30pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Looking forward to this James...
31st Mar 2023 3:37pm |
its taking a while it seems! got some wiring sorted today, waiting on a fe coolant parts, hopefully fuel sorted tomorrow Cheers
31st Mar 2023 10:06pm |
Coming along. Decided to put loom inside.
Click image to enlarge Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
1st Apr 2023 7:20am |
She's in and running. Very pleased with results. Loads of torque and incredibly smooth. Def worth the effort. ( despite slight engine issue with over fuelling, burning oil, leaking injector or similar on cold Start up)
5th Apr 2023 8:10pm |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 289 |
Good to see another m57 conversion, what’s your plan for the air intake (looking for ideas on how to connect mine up) 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
5th Apr 2023 8:52pm |
Remove std filter, adaptor from maf housing to 3" pipe, filter in that pipework. Jist needs to be big with good air flow. Can run as she is for a while. Cheers
5th Apr 2023 9:15pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 496 |
@ib73 you could have 2 options, fit the 535D rocker cover as this used a remote say airbox or MW Machines is after creating a side panel for the air box so you can fit to a snorkel.
6th Apr 2023 10:26am |
think the adaptor i bought was £30, plus some 3" pipe and a filter housing if not filter on end of pipework. depends how much you want to spend. Cheers
6th Apr 2023 4:34pm |
Jon w Member Since: 22 Dec 2015 Location: North East Wales Posts: 204 |
Interesting this James. Couple of questions:
What variant of engine was it? Range rover? How come you swapped the R380 out? Does the puma box sit in the standard puma position for transfer box mounting etc? THen was it just a case of welding in the engine mounts? Thanks |
6th Apr 2023 7:13pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5162 |
Great to see it went nice and smooth for you, the engine conversion we did in a rover metro, the info was very questionable.
How much did it set you back? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
8th Apr 2023 1:19pm |
Its alot of £££ 5o d9. Engine was £325, downpipe £400, clutch, adaptor £1k. Puma gearbox, t box and props £1k. Ecu bits loom, service items, prob £1k engine mts £500 plus pipework and pas parts. So alot.
R380 apparantly wont take the grunt for long. fitted puma gbox and tbox in std place with puma props worked fwd from there. Its a 185 version Jon. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Apr 2023 2:26pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1860 |
Plus a big labour bill for those of us without your skills Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
8th Apr 2023 4:27pm |
