![]() | Home > Puma (Tdci) > Gear stick head |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
You might want to take a look at this thread. Essentially you either need a new (or pre-owned) genuine gear lever, or you can fit an absurdly over-priced Bowler type contraption, or you can do this:
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
Thanks
It's not everyone's cup-of-tea, but it is much more comfortable to drive with than the original plastic thingy and to me is reminiscent of the good old days when there was no plastic in a Land-Rover cab.
Another attraction is that it cost me £4 for the knob and about half-an-hour of work to fit. The postage on a new gear lever would be more than £4! ![]() I've become quite attached to my knob. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
Nice knob Blackwolf… I notice you’ve got 3 heated seat switches. What’s going on there?! |
They don't do anything (except fill the holes). At one time I had the intention of using them for n/s, rear, and o/s worklights, but in the end fitted the switches for the lights in my Mud roof console. So they are spare.
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
I like that and will do it similar ![]() Quick question, does the carpet have to be removed to loosen the cuff or is there another (easier) approach? |
As I recall, you can push the top end of the rubber boot down the gear lever far enough to release the gear lever without disturbing the carpet. At least, I think that is how I did it, it was quite a long time ago now.
Thank you, that worked very well
![]() Clamp the old head in the vice, saw all around to the metal axle and turn the shaft vigorously. You can feel that something will come loose. The old head can be removed very quickly by strong axial pull and constant turning. ![]() |
Yup, that's what I did. Then tap an M12 thread on the end, and fit a £4 knob, and you'll have a better and nicer-to-use gear lever than the original.
![]() Many people have now complimented me on my knob, although a few have laughed at it. Love it or hate it, it feels very nice in your hand as you drive. ![]() ![]() |
I will also take a black plastic ball and let the bottom of my favourite cartridge in flush on the top. When finished will post pictures
![]() Edit: Ready ![]() |
DICKO1995 Member Since: 02 Feb 2024 Location: High Peak Posts: 10 ![]() ![]() ![]() |
Hi,
Does anyone by chance know the size of the shaft/bar that is under the rubber gear knob? I have designed and started milling an aluminium gear knob, this will slot onto the shaft and grub screw on to secure it. Before I saw off the top to find out the size I just wanted to ask to see if anyone knows. Failing this it can be tapped to fit once down to the bar. Thanks |
It can be threaded M12 without any adjustment. Whether it is actually 12mm dia or marginally smaller I couldn't say, but I found it very easy to start an M12 die without any special preparation and the thread certainly appears to be full diameter afterwards.
This is an M12 threaded knob and a standard M12 half nut. ![]() Click image to enlarge |
Thanks Blackwolf
