Mike the vike
Bit of steel on transfer case drain plug magnet | |
Hi all, new to forum,
Hoping for advice.
Recently replaced clutch on puma2,4 with mt82, during test drive, stopped and engaged diff lock, then tc jammed, and eventually "unjammed" with a bang.
I then drained tc oil and found a small bit of steel on drain plug magnet, looks like something that would house a pin in 4mm or 5mm diameter.
Have heard that if incorrect bolts are put in when tc joins transmission, a bolt too long can touch a gear and lock tc??
See pictures,
Ps- since this happened, everything still works fine, no noises, diff lock works, but obviously something has let go.
Any advise would be appreciated.
