Home > Maintenance & Modifications > Sankey trailer modifications
Hicap trailer - Yes or No?
Stick with the orginal Sankey tub - Keep is simple
20%
 20%  [6]
Go for it and fit the Hicap body
37%
 37%  [11]
Mess around and extend the Hicap body
10%
 10%  [3]
Forget it and do the sensible option - buy a standard IforWillliams trailer
31%
 31%  [9]
Total Votes: 29
Page 2 of 2 <12
Green Machine
Great job Paul - think your perseverance has paid off in the end! Looks great. I'm guessing that it has so far cost you rather a lot more than an Ifor Williams or equivalent, but ultimately it's worth more as something that's much more bespoke. And above anything else . . . it looks the Dog's nuts! Thumbs Up
edit: sorry Paul - just read your earlier post fully. If it only cost the same as a second hand Ifor Williams then it's a total no brainer for me! Much more appealing! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #98519 6th Nov 2011 10:37pm
JWL
Did you sort out your reverse lock conundrum? I did have a thought that a solonoid, such as a central locking part or any other that can be found all over the place, linked to a mechanical mechanism on the hitch which could be activated by the reversing light. Connection to the vehicle either by a 12S plug or a seperate DIN plug and socket which would be exclusive to the trailer. If you did use a 12S you could activate the Hi-Cap reverse lights as well in a conventional manner.
Post #98521 6th Nov 2011 11:04pm
ZeDefender
Mega drooooool Thumbs Up
Would love to do something similar but no way would I get TÜV approval - you have to have road tax, insurance and a separate registration for a trailer here Shocked Tell someone you love them today because life is short.
Post #98529 7th Nov 2011 7:18am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
That looks really smart Cool not sure if I would want to abuse it as much as I would my ifor coz its too smart.
Why bother with the extra spare wheel? surely it just gets in the way more often than you are going to have a double puncture Confused
Bit envious really Thumbs Up 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #98631 7th Nov 2011 7:05pm
JSG
Nice work - looks better now you've sorted the overhangs out Thumbs Up John
2011 Tdci 110 CSW XS
Post #98678 7th Nov 2011 8:51pm
LR90XS2011
Best trailer ive seen on a landy well done DEFENDER 90 TDCI XS,
Post #98690 7th Nov 2011 9:16pm
RLD
this is my Sanky
have a look on the D3 site for sanky trailers lots of stuff on there Whistle RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #98750 8th Nov 2011 9:58am
RLD
from 2 weeks ago the white one is Wiggs of the D3 forum have a look at my sanky build or Wiggs photos RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #98771 8th Nov 2011 12:34pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
That is a quality bit of fabrication. I want to make one now!
Pete
Post #98874 8th Nov 2011 11:09pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Paul
Apologies for digging up an old thread. I 'm inspired by this post and I'd like to replace my rusty sankey tub, with one from a 110 hi cap. I'm interested to hear how you mounded the tub to the sankey chassis, was it relatively straight forward? Any pics of that wld be awesome.
Thank you for showing the idea.
Regards
Bows
Post #264107 5th Sep 2013 8:43pm
JWL
Another thread revival but I thought it better to keep things on the forum a little tidier by keeping discussions about Sankey trailers in one place.
I have a narrow track Sankey with a Hi-Cap tub on it and wouldn't mind widening the wheel track. Just had a bit of a think and have begun to wonder about whether getting a Discovery back axle and unbolting the hub assemblies off the axle tubes then joining them together at the right distance apart with a length of tube. Then weld to the tube the spring fixings that could be cut off the existing Sankey axle. By using a Discovery axle it provides disc brakes that could be activated by a master cylinder setup on the drawbar copied from later Sankey systems.
Over the years I've built various trailers from car transporters to specialized farm equipment, the major question is would the trailer then have to be inspected by VOSA, if that were to happen then surely you could get it re-reted on its load carrying capacity due to having hubs from a Discovery that would have a recognised weight rating.
Post #305500 6th Feb 2014 12:46am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
By the time you have fitted the MK3 hitch/braking system you would have made some significant changes to the chassis, combine that with the new axle and the non standard tub and you haven't got much of your old narrow track left. The Narrow Track is exempt from testing as it is before 2011 but with all those changes it's going to fall into a very grey area. Why not hunt out a MK3 rolling chassis which will give you disks and thhe wider track.
You could look at the cheaper ones with a rotten tub and re-use your HiCap body. www.td5.org
Post #305700 6th Feb 2014 7:52pm
JWL
Yes fair point, I was just thinking about what I have sat in the garden that's to hand. Fabricating a pivot to push on a hydraulic master cylinder to activate the brakes in my eyes is not a huge job. I was wondering more on how far you can go with "upgrading" a trailer before anything like an IVA test is required. There are threads on forums where people have extended the chassis of the trailer, technically are you supposed to take your trailer in for a test if you swop the Nato ring hitch for a 50mm ball coupling. I posted my queries on here as this thread has caught the attention of some who may have changed a bog standard Sankey into a camping trailer and I wondered whether they had put their trailer in for a test. If I did take it for a test then there shouldn't be any reason why I couldn't upgrade the Sankey from a 01 class as Narrow Tracks are rated at 0.75 tonnes to an 02 class which would be up to 3.5 tonnes.
Post #305736 6th Feb 2014 9:32pm
Page 2 of 2 <12
