![]() | Home > Puma (Tdci) > 2.4 tdci brake flexi hose |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
If nobody knows I can always measure mine, I've got a standard height non abs 110.
I ordered mine from david@llama4x4.com, he makes them, so if your car is higher or lower I would advise you to give him a call. a defender from 1984 pretending to be a puma with a touch of Range Rover |
Ad-doublecab Member Since: 05 Jan 2021 Location: London Posts: 65 ![]() ![]() ![]() |
Amazing If you don’t mind that would be really helpful!
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6654 ![]() ![]() ![]() |
The Puma front hose (SHB500230) is approx 430mm end-to-end. It has M10x1.0 female fittings on each end.
Thank you Martin
I guess you are sorted now. a defender from 1984 pretending to be a puma with a touch of Range Rover
