![]() | Home > Off Topic > “Normal” car under body protection |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
I had my 105 done by buzzweld. They prepped and then applied their own products. Wasn’t mega cheap but was well done tbh.
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
That’s absolutely stunning!
Mine…. ![]() Click image to enlarge ![]() Click image to enlarge 2002 110 td5 |
Thanks, can’t beat an Alfa
![]() Given yours is a fair bit newer I’m assuming it’s got underfloor panels and stuff which will restrict access? That lanolin spray stuff gets good reviews, or you could opt for the thin ML dinitrol stuff in clear blasted on by compressor. Good luck ![]() |
It has, although I’ve taken them off in prep for this job. I had thought of the lanoguard stuff, and was hoping someone on here had used it. To be honest, I don’t think any coating will be effective if I don’t do similar prep to what I would do to the defender. I don’t think I’ve got the time or the enthusiasm to maintain two cars in that way
![]() I can see the merit in the ml and I’ve got some cans of that left over. 2002 110 td5 |
I think that realistically, if you don't do the prep then no product will work well.
Whilst I appreciate the relative difficulty of getting underneath, I'd suggest that there are fewer nooks and crannies on a car without a separate chassis and you may be pleasantly surprised at how much simpler it would be to treat. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I think you might be right there. I’ve gone for the lanoguard on this occasion. I’m going to really enjoy spending the best part of a week under another one of my “classic” (old rusty) cars. 2002 110 td5
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 847 ![]() ![]() ![]() |
Hi all
Over the last few years I have switched to Lanoguard. Before applying I normally visit the local truck wash company and get them to hot wash the chassis and underside. Then I let it dry for a week before getting underneath with a wire brush. Then I treat any rust with Aqua Steel, let it cure for a few days before applying a good soaking of Lanoguard. The chassis and underside components really do look good after the process. Jim |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3651 ![]() ![]() ![]() |
try Zegato he does all sorts
view-source:https://www.defender2.net/forum/topic10467.html my go to product would be Dinitrol https://www.dinitroldirect.com/product/din...rosol-cans DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
