Home > In Car Electronics > Radio Code 2011 Defender
hbi
Norway 2011 Defender 110 Puma 2.4 SW Santorini Black
Hi,
I have a 2011 Defender with original radio XQE500540 which needs a radio code after some maintenance.
I've been to the local LR dealer in Oslo who can't find anything in their system and didn't get anything from their contacts in UK either.
I was advised to send an inquiry to info@landrover.no They could not find anything in their system either and have forwarded the request to England. I have the serial number available.
Since it locks after 3 mistakes, I don't want to try too much weirdness. I have also tried onlineradiocodes.co.uk with no luck. Does anyone here have any good advice?
/Best regards
Post #987069 27th Mar 2023 8:43pm
LR90XS2011
my dealer wrote my number in the front of the service book DEFENDER 90 TDCI XS,
Post #987082 28th Mar 2023 5:45am
familymad
Mine was on the actual unit!! That was after going into the dealer and getting the code from the parts dept then taking it out and realising I had wasted a 40min trip! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #987084 28th Mar 2023 6:30am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I found mine taped to the top of the battery 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #987090 28th Mar 2023 9:00am
When the vehicle left the factory, the code would have been taped to the battery so that on PDI the radio could be enabled. If the radio and battery are the originals, the label may still be there.
Post #987127 28th Mar 2023 4:26pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Here in the U.K. I've used this company https://www.onlineradiocodes.co.uk/ maybe there's similar in Norway or perhaps they can cover export models as well.
Good luck Thumbs Up
OOPS sorry just read your post properly Whistle Just because you're offended doesn't mean you're right.
Post #987179 28th Mar 2023 9:15pm
hbi
thx guys. received a code from LR UK now and hopefully this one works.
Post #987273 29th Mar 2023 7:03pm
J!m
Belgium 2010 Defender 90 Puma 2.4 HT Alaska White
Hi, I have the same problem, no radio code for a Defender 2010. How can I take contact with LR UK to request the code?
Regards!
Post #1015655 19th Nov 2023 4:02pm
hbi
Hi, I contacted the Land Rover dealer in Norway and they received my code from UK. Not much help for you I guess. Sorry
Post #1016273 24th Nov 2023 5:24pm
