Home > Tdi > Intermittent 300tdi starting issue |
It depends on your pattern of usage but that sounds very much like a bit of air is getting into the fuel system, particularly if these false starts follow periods where it's been standing for longer. Darren
23rd Mar 2023 10:29am |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 399 |
I had something very similar (albeit on my old 200tdi), the lift pump was allowing fuel to run back. Would start on the fuel left in the injector pump and then cut out.
23rd Mar 2023 11:58am |
Davidarnol Member Since: 04 Aug 2017 Location: Scotland Posts: 21 |
Thanks, I changed the fuel cut out this morning so will see if that cures it, during the changeout in that confined space my elbow bumped into the fuel return line between the front injector and the banjo fitting on the pump, I thought I heard a gurgling sound for a second up at the injector, not sure if that could allow air in to the high pressure side of the system? (No leak up there with the engine running).
Once the engine started ok I cracked open the bleed screw on top of the (new) fuel filter, diesel started coming out but quite slowly, should it spray out if the lift pump is in good order?, thanks for the suggestions so far. |
23rd Mar 2023 12:17pm |
With regard to the first reply the issue can happen anytime, engine hot or cold, left overnight or off for a short period
23rd Mar 2023 1:15pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 814 |
Lift pump isn't critical, but it can get blocked which does cause problems.
My 1994 started running badly and cutting out. I eventually traced it to the fuel lift pump which has a strainer/gauze in the cap and this was full of sludge and leaf mulch etc which was badly restricting fuel delivery. I also discovered the plunger was goosed so it wasn't actually doing any pumping anyway and from what I read on the internet our engines don't need it. I refitted the faulty pump after cleaning out the gunk and it ran great, good as new for several weeks until I got a chance to fit a new, functioning one, that made absolutely no difference. |
23rd Mar 2023 1:36pm |
Turned out to be the fuel spill return line, the sound deadening under the bonnet was loose and with the bonnet closed it pushed down on the return line to the injector pump causing it to let air in, I shortened the pipe and secured the sound deadening and I am now back to first turn starting, hot or cold, thanks for the Suggestions
27th Mar 2023 9:53pm |
