![]() | Home > Td5 > fuel pump replacemnt |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1140 ![]() ![]() ![]() |
You cut a hole in the floor. Sounds rought but trust me to have access for future is nice. I mounted a plate with screws
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
Yeah,
saw that LRM article of doing that.. and really a good ideal Tank out So..... remove NSR wheel lower tanka bit and you can get at the fuel pipes and the electrical connector After that, getting tank out was simples..... Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
ok so all sorted. ...and you can replace the tank and fuel cradle yourself.
Bascially, slide your feet under the car with fuel tank on your legs. the power cable is long enoguh to plug in at this point Lift up tank feeding fuel filler over crossmember alomg with hose to fuel filler cap. Using axle stands to roughly hold tank in place and feed breather pipe to NSR wheelarch Using trolly jack and block of wood lift tank up till you see the top through NS Wheelarch and fit With 2 axle stands and some wood hold tank in place. remove trolly jack Take fuel tank cradle and fit in middle. Hole uop with 1 hand while using trollyjack to puch tank and cradle onto right position Slide studes into rear crossmember ( best to do this from the other end of the cradle. If the studs line up just push at the front end and it;ll slide in Fit M10 20mm bolts at front loosely Fit m8 nuts at rear crossmember Remember to cover everyting with cppper grease so its easier next time Was so chuffed when she sprangh into life .... Now to fix brakes on the S3 and the head gasket on the other td5 .... A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5235 ![]() ![]() |
i replaced mine with YRM Cradle. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
