Home > Technical > damaged transmission housing?
Page 1 of 4 1234>
TheTechnobear
Spain 2007 Defender 110 Puma 2.4 SW Chawton White
whilst investigating the diff lock issue (separate post)
i noticed that the transmission housing (correct? correct very much a newbie!), had an oil leak...
it seems to be coming from a hole in the casing, see photo (sorry a bit hard to see - but you can hopefully make it out)
Is this really, a hole in the casing, and something thats really damaged Big Cry or is it a normal casing 'feature', and i 'just' have a leak...
any suggestions, about what needs to be done and how serious it is...
thanks again
Mark
oh, and a really newbie question... is the transmission missing a mount here? seems odd to have a bracket, and a fixing but not connected...
Post #98637 7th Nov 2011 7:16pm
bob neville
Hi Mark
Looking at the leak that does look like damage and a hole in the case. Any chance you can clean the oil off and post another picture ? If it is a hole I would hate to guess how that has happened. At least you do not appear to be losing much oil - I hope there is some left in the box.
Pic 2 - nothing is missing, they are all like that and there are a number of posts on the forum about it.
Bob
Post #98644 7th Nov 2011 7:48pm
TheTechnobear
thanks bob,
will clean off the oil tommorow in the daylight and post up a better pick.
as you say very hard to see, black on black Smile
if you enlarge, you can just about see it....its like a shallow U shape, on the housing... almost looks like a 'chip'
(or alternative, like the shape they put on things to allow you to prise things open... if that make any sense)
mark
(as you say, hopefully its only a small loss of oil - as the gear change seems smooth enough, i only found it as i was checking out the diff lock ... but obviously id like to get it sorted out now ive noticed it!)
Post #98647 7th Nov 2011 7:56pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
The hole is there to let oil out if you have a leak...is it oil or clutch fluid ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #98648 7th Nov 2011 8:00pm
TheTechnobear
so the hole in first pic is normal?
... as a newbie, i seem to be hearing that alot ... oh they are all like that sir Wink
... but i have a possible leak? or excess oil... can i tell which ? Smile
thanks guys
Post #98650 7th Nov 2011 8:03pm
fekete
Yes the hole is normal but you need to check whether its oil or clutch fluid.
Yes a possible leak but it only looks minimal NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #98653 7th Nov 2011 8:05pm
TheTechnobear
ok, will check tommorow...
i 'know' what normal oil is like, but clutch fluid - assume clutch fluid is not as thick, and less oily Smile
Post #98655 7th Nov 2011 8:07pm
bob neville
To dark and cold to go and check mine to see whats 'normal'.
As Fekete says, it could be normal. Maybe an overfill of the gearbox has caused a leak.
I will have look under mine Tuesday in daylight to see what should be there.
Bob
Post #98658 7th Nov 2011 8:09pm
fekete
Thumbs Up
I would not worry to much it will still be fine to drive just keep an eye on it
let us know what you find NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #98659 7th Nov 2011 8:11pm
MK
Looks quite black that oil. Gear oil is vary pale. Of course it can be contaminated with clutch powder. Puma 110" SW
Post #98725 8th Nov 2011 12:18am
LR90XS2011
if thats the clutch bell housing then I would suspect the engine crank shaft oil seal . like Feteke states I wouldnt worry but keep an eye on it and the oil levels, if it is engine oil check that all the breathers are clear and the crank case is not pressurising (noticable pressurised air flow out of the filler cap when removed with engine running) DEFENDER 90 TDCI XS,
Post #98728 8th Nov 2011 6:15am
RED-DOT
Land Rovers years ago used to tear the crankshaft oil seal behind the flywheel after being stood for a while and also on a really cold night but they almost always re-sealed again given time. I believe the seals up to Series III were made of leather... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #98757 8th Nov 2011 10:47am
TheTechnobear
i checked, and from my (uneducated) guess, id say it seemed like engine oil, it was dark and same consistency ... though ive never see gearbox oil.
i then cleaned it up...
and took her for a drive, 15mins, mixture of windy roads a quick blast on motorway.
got back, it was basically still clean, but there was some seepage from come the hole - but very small (small teardrop sized).
ok, so going on LR90XS2011 suggestion, popped the bonnet.
first checked oil level on dipstick, whilst engine warm and idling... this seems high, over the max marking.
(i think they may have overfilled it when they changed the oil pump, wassame when i last checked a week ago)
next, took the engine oil filler cap off, whilst idling- it didnt seem very 'pressurized' .. i.e. no hiss or anything.
though hot air was being blown out when it was off, say like a hairdryer on slow speed.
i didnt leave the cap off for that long, 15 secs i suppose. (due to it blowing splashes of oil out, and making a mess Smile)
... so not sure it would 'continue' if it left it off.
thoughts?
im thinking of taking to the garage, so they can look at the diff lock - would be good to know what to highlight to them,
if something needs to be done.
cheers, and thanks again for the comments from all
Post #98795 8th Nov 2011 4:52pm
JSG
You need check the oil level with the engine off - when it is idling the oil is still being pumped around the engine. John
2011 Tdci 110 CSW XS
Post #98803 8th Nov 2011 6:09pm
Green Machine
Technobear - as JSG says, the dipstick measures the oil level in the sump, so needs to be checked with the engine off. Allow 5-10 mins after switching off for the oil to drip down through the engine back into the sump before checking the level. The dipstick doesn't give an indication of the oil level whilst the engine is running, as oil will be splashed onto it anyway, regardless of the actual oil level. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #98815 8th Nov 2011 7:13pm
Page 1 of 4 1234>
