Home > Modifications & Maintenance (L663) > Led light bar install
Buz1500
Now that I’ve had my new P400e delivered I’m looking into installing a Lazer Linear-18 light bar into the lower grill using integrated fitting kit by Lazer. One question I have relates to the X-Dynamic badge on the grill, Is it removable? The reason I ask is that the light bar will extend partially over the area of the grill where the badge sits and the grill needs to be cut to fit the light bar.
https://www.lazerlamps.com/land-rover-defe...it-g2.html 2019 Range Rover SDV8 Autobiography
2023 Defender 110 P400e X-Dynamic HSE - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #986024 18th Mar 2023 4:46pm
Defendit..
Netherlands
Looks like clipped, don't know if it can be removed from the front whitout breaking.
LR155954
 No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #986441 22nd Mar 2023 8:58pm
Buz1500
Yes, it is clipped in place and quite easy to remove.
Next problem......
I need to feed the light bar cable from the relay to behind the lower grill where the light bar is being installed. According to the Lazer YouTube video, you just route it between the headlight and the radiator but they don’t actually show this in practice. I’ve looked at doing this but there doesn’t appear to be any openings to the space behind the grill.
Anyone else undertaken this? 2019 Range Rover SDV8 Autobiography
Post #987053 27th Mar 2023 8:04pm
Buz1500
Finally managed to route the light bar cable successfully after getting advice from a technician from Lazer.
Just need to confirm that I’ve taken the 12v feed correctly. I’ve currently connected it to a spare stud on what I believe to be the accessory port located next to Red plastic case housing the live stud used for jump starting. 2019 Range Rover SDV8 Autobiography
Post #987197 29th Mar 2023 8:26am
Tim in Scotland
Yesterday I tried searching in the PowerfulUK videos on YouTube and couldn’t find where they mention this connection - in one of their recent videos Simon was installing an accessory and that connection next to the red positive charging post box was where he said what he was connecting should be connected and how kind of LR to add the feature! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #987199 29th Mar 2023 8:47am
Buz1500
Hi Tim, thanks for your reply.
Yes, I also saw the Powerful Uk video so I reckon I’m okay.
I’ve now come across another problem. After spending all day fitting and connecting yesterday, and successfully testing whilst on my drive. I took the car out for a run once it was dark but the light bar didn’t activate when I selected high beam. I assumed I’d got a faulty connection so I thought I’d leave until the morning before I investigated.
I’ve now started my car this morning and the light bar came on the first time I selected main beam but now won’t reactivate after selecting dip beam and moving back to main beam.
Thoughts please. 2019 Range Rover SDV8 Autobiography
Post #987205 29th Mar 2023 9:28am
Buz1500
Problem now resolved.
The Earth I was using wasn’t good enough. Using a multimeter whilst the car was running highlighted that the earth wasn’t good enough. Reconnected via the factory earth pole. Light bar is now working as required. 2019 Range Rover SDV8 Autobiography
Post #987211 29th Mar 2023 10:59am
Nuclear Nick
Is the live feed fused close to the connection point?
Post #987222 29th Mar 2023 1:28pm
Buz1500
Thanks for your reply
Yes, as supplied by Lazer Lamps.
Please see my previous post as I’ve now resolved the issue. 2019 Range Rover SDV8 Autobiography
Post #987225 29th Mar 2023 1:43pm
walfy
Do you have matrix lights? Did you have to cut into the loom to fit this kit?
I'm after the same but I only need the loom and mounting brackets from lazer lamps. Just need to find a retailer that will do a decent deal 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #987231 29th Mar 2023 2:26pm
Tim in Scotland
I have seen some posts on FB groups that people have had to take their cars fitted with matrix headlights into the dealers to get their light bars coded so they will switch off when the matrix activates it’s “dip” pattern which isn’t really a “dip” Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #987240 29th Mar 2023 3:46pm
Buz1500
I have the Premium LED headlights, not the Matrix lights.
The Premium LED headlights have a 12v high beam trigger wire, which is what I've tapped into for triggering the Light bar relay using a POSI-TAP connector.
These connectors are used widely amongst the off-road driving and adventure motorcyclists as they provide an easy way to add additional lights and accessories without compromising the factory wiring.
https://www.posi-products.com/posiplug.html 2019 Range Rover SDV8 Autobiography
Post #987243 29th Mar 2023 4:05pm
Buz1500
I tested the light bar last night once it went dark. It throws out an impressive amount of light and is a significant improvement over the factory high beam.
The only issue is that it will only come on when you manually select high beam. If you have the lights set to auto with the auto high beam function enabled it does not come on. It would appear that the auto function uses a different wire to the manual high beam wire.
You could view this as a good thing as it allows you choose if the light bar activates. I think I’d actually prefer to have it the other way round so that the auto system controls the light bar as it’s quicker than me in reacting to other traffic.
Anyone know which wire on the headlight loom is fed by the AHBA? Or is it the CAN system? 2019 Range Rover SDV8 Autobiography
Post #987310 30th Mar 2023 9:21am
Defendit..
Netherlands
Can Bus High Beam interface
https://www.devon4x4.com/can-bus-highbeam-interface.html No Mud flaps for my 90.!
Post #987329 30th Mar 2023 10:59am
Buz1500
Yes, I'm aware of these devices. The company that supplied the light bar (Lazer Lamps) also supply these.
The question is does the ABHA system use CANBUS? 2019 Range Rover SDV8 Autobiography
Post #987330 30th Mar 2023 11:02am
