![]() | Home > General & Technical (L663) > Offroad Camera = No Parking Sensor? |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3460 ![]() ![]() |
Yes noticed this on mine, can’t say I’ve seen a way to change it. 24MY 90 D250 HSE, Tasman Blue
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2538 ![]() ![]() ![]() |
Trying to do a three point turn on a narrow forest track, I would have thought that parking sensors would be an advantage when trying to avoid those dirty big trees that are in your way. Defender 90XS SW
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
If you go into the cameras menu using the icon on the left side of the pivi-pro screen, then look for the speaker icon and check it isn’t checked with a cross - I use that a lot off-road to silence the parking sensors as they pick up every blade of long grass so I silence them and sometimes I forget to reinstate them BUT they should reset to audible if you switch of the car and restart it. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 526 ![]() |
Thanks Tim. Based on your recommendation, I checked but the option seems to be only visible in the 'on-road' camera view. When I switch to the off-road view (the one I use a lot), there's no speaker icon - instead there's the toggle to 'see through bonnet' view. Am I looking in the wrong place?
In Offroad cams view, when I drive in longish grass the parking sensors activate and when they come on I get a speaker icon appears on the screen. It only stays silent until until I leave the grass then it resets and comes back next time something brushes passed the front. I’ve just tried it on my drive but the sensors aren’t being activated even though I’m parked close to my garage door. I’m trying not to take the car off-road as it goes in parted next week but I’ll be taking it out for an “exercise” drive so will try to find somewhere to trigger it and take some photos. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Ah, I see what you mean..
Is it the collision detection system rather than the regular parking sensors? I find I can reverse to near dangerous proximity to objects in offroad camera view mode without a peep from the sensors. If I then switch to on-road camera mode, without moving the vehicle, the warning sounds are blaring away. I suspect I might even be able to hit an object whilst reversing in offroad camera mode, before a sensor alarm comes on. I feel an experiment coming on.. |
I checked again last night - reversed towards an object in on-road camera mode, moved until the beeping was frantic but not solid.
Switched to Off-road camera = silence. Moved a little closer, not a peep. I would think that there must be an offroad silencing option that I've ticked in Pivipro, but I can't seem to find it. |
