![]() | Home > Td5 > Door Locks |
Puddings 3112 Member Since: 05 Dec 2020 Location: Down South Posts: 49 ![]() |
I regularly use Abus lock lube PS88 (good squirt after every off road trip or vehicle clean) and so far this winter no freezing up issues. It also worked on freeing up a rusted up gate padlock so seems to be a good recovery aid too. It comes in a small 50ml can which is small enough to carry in my day sack.
Shop around for it though because it ranges massively in price - you should be able to get it for around £8 per can |
mpald Member Since: 16 Dec 2016 Location: North East Posts: 50 ![]() ![]() ![]() |
Thank you for the suggestion; I'll give it a try and hope for warmer weather!
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 335 ![]() ![]() ![]() |
A perennial problem, I found that by moving from a 3 door 90CSW to a 5 door 110CSW (with central locking) I increased the chances of having at least one door unlock in cold weather by an amazing 66%!
Pah...
I suppose it's the ultimate reason to get a Rag Top ...
It is somewhat ironic that when owners wish to gain access to their Defender they are prevented from doing so, but scrotes and miscreants seem to be able to hop in and drive off with very little hindrance.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
So I live in the great white north and we still have three feet of snow on the ground here. Regularly goes to -20C but its raining today (yay! Snow going down the drain). I drive my 110 all year long and I wash it all winter.
You should just squirt some WD 40 into the barrel and let it be. WD = “water dispersant” it is a very crappy lube but a great moisture protectant and dispersant. I use the power locks and rarely use the key. When I first bought it I blew out and cleaned the locks with an air line and then sprayed WD on it and have never needed to do it again and that was eight years ago. It may be that humidity gets into it and freezes where you live so regularly doing this would prove beneficial. Good luck. ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
