Home > Maintenance & Modifications > R380 Gearbox Oil and Gear Selection Problem |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1041 |
Ahh a good old oil discussion thread..
As you probably know the correct oil for the R380 is MTF94. Living in France I searched for this and found nothing, but find it is very reasonably priced at your standard UK outlets. So while ordering other parts I bought 3 bottles at LRPARTS (they have some different options): https://www.lrparts.net/vyk000010-mtf94-ge...ottle.html So this is the right stuff and it is not pricey. Now when I was putting it in I could not help notice that it looks, feels and smells like ATF (Automatic Transmission Fluid) and not your typical gear oil. So probably you would want to use ATF and not gear oil if you cannot find MTF94, it has much lower viscosity than gear oil (as in more liquid) Needless to say that what came out was not MTF94 or ATF but fairly heavy gear oil and after oil change the gearbox changed sooo much smoother, slick almost. Still 3rd gear notchiness remains, just syncro wear - no oil will change that. |
16th Mar 2023 8:58am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 316 |
Ashcroft Transmissions recommend this -
https://www.eurocarparts.com/p/triple-qx-a...-522776012 I used this on my Ashcroft recon box, easy to get hold of as most Euro Car Parts locations stock it. |
16th Mar 2023 9:39am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1599 |
i suspect that fresh oil won't fix your issue but it might help if its not been done in a long time.
gear oil as above is fine for diffs and t box but ideal spec is mtf94 or atf if its been run on that previously. lots of info on ashcrofts transmissions site most likely its ready for a rebuild/ refresh. i wouldn't waste slick 50 in it until the problem is fixed |
16th Mar 2023 10:13am |
