Home > In Car Electronics > Windscreen power source |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
Great work Paul, you're a legend!
MM |
16th Mar 2023 9:18am |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 205 |
Paul,
That is awesome - terrifying, but awesome..👍👍 Many thanks to both you and Penfold. I assume that I can get the switch apart using my hammer - a bit like cracking a Walnut..?? 🤔 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
16th Mar 2023 10:15am |
lol...maybe try a small screw driver first before going the full Tonya Harding on it...
16th Mar 2023 11:00am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 503 |
Use a jeweller's screwdriver to CAREFULLY unclip the two halves of the switch -
Click image to enlarge Modifying the switch is free - but, it's then non-standard. Using a relay to reverse the switch's polarity costs money - but, keeps the switch standard. Wired like this - Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
16th Mar 2023 1:20pm |
Ah, got it.... So I'd need an extra relay before the timer relay to reverse the polarity to it..??
Either that or modify my switch (as per the excellent instructions) thereby making the switch 'non standard'.. Ok, I'll have a go - but I can't promise that I won't be back with more questions 😃 and possibly more purchases from Paul to replace broken switches, connectors, wires, centre consoles, dash pads, bulkheads etc. Right, I'm off to find my extra small hammer....👍👍 Cheers all. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
16th Mar 2023 4:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17551 |
The nice thing about these switches is that with imagination they are almost infinitely modifiable. A few cuts and straps and you can make them do almost anything. You can swap the latching and non-latching mechanisms between switches too. The switches in the 2x3 switch binnacle on Disco and Disco2 are the same family as well and great candidates for modification.
16th Mar 2023 6:01pm |
Cheers Blackwolf - good to know..👍👍
I am, in this case, going to stick to the script and not deviate in any way from the directions above (I know you're not advising me to..) - I'm well out of my comfort zone. Gimme a cylinder head to rebuild anyday.😄😄 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
17th Mar 2023 5:18pm |
