Home > Technical > Rear Wiper and Wash not working
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
2007 Tdci. Both not working. Fuses are intact.
Front wash works ok.
Done a search on previous posts.
Trying to get my head round what would be the common failure given that they are on separate switches and the washer pump isn't in the rear door.
Post #985637 15th Mar 2023 2:10pm
Martin
Site Admin
The only common point is the fuse, which is the supply to the rear washer switch and to the rear door for the motor relay.
It's Fuse 10, 10 Amp.
Check it again, take it out and re-seat it, or simply change it anyway (if no spare then swap for fuse 18 - left hand side lights).
Check for voltage on it with a meter with the ignition switched on.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #985639 15th Mar 2023 2:22pm
keef9t
Thanks Martin, I'll have another look.
Post #985645 15th Mar 2023 3:22pm
