![]() | Home > General & Technical (L663) > Warning check this |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2720 ![]() ![]() |
Very glad you mentioned it - just checked mine and found this:
![]() Click image to enlarge ![]() Click image to enlarge Will be having a stern conversation with the dealer on Monday. Have added some string to hold the hose clear of the filter for now. ![]() Click image to enlarge |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3020 ![]() ![]() |
Yep that's the one.
Cable tie will keep it from getting any worse until it can be properly sorted. |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 524 ![]() |
My D250 MY23.5 delivered in October 2022 seems to have a different plastic 90degree bend connector.
Slightly more angle (>90) on the plastic 90degree bend on the left of the images. (It also looks like a vertical feeder pipe has been moved/changed from plastic 90bend too when comparing to the version in Retroanaconda's pics at 10 o'clock) ![]() Click image to enlarge |
Intercooler Member Since: 04 Jan 2022 Location: Schwabenland Posts: 27 ![]() ![]() |
On my Defender (Year of manufacture 6/2021 MY22) there is enough space between the radiator hose and the air intake. See photo.
![]() Click image to enlarge Regards ![]() |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
Just goes to show you still need to carry some baler twine even in the latest iteration of the Defender! No amount of over the air software updates would sort that out. Defender 90XS SW
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 276 ![]() ![]() |
Just realised that I have this same issue. The hose is rubbing against the filter and it's showing signs of damage. Did LR get this replaced and fixed? If it's been removed from the service bulletin how critical is this? Last thing I want is to spend 1/2 a day drinking coffee at LR Service.... Thanks! 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
Mine hasn't been done yet, there was a two month wait for a courtesy car and it was due to be done next week.
Then, l asked them to also look at the door outer plastic trim which has warped a little on the passenger door. And also apparently my missing USB ports are now in stock. Can they do that as well? That will mean we need it for two days they said, and l've gone to the back of the queue so it's now being done at the end of April. |
Nazca sand eddie Member Since: 03 May 2022 Location: England Posts: 10 ![]() ![]() |
Does anyone know if a new TSB number has been issued?
It’s being done on the 31st of this month. That’s the first date I could get a courtesy car. In the meantime I’ve added a bit of plastic to stop it rubbing through:
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Here’s what my 20 hours old D250 has under the bonnet to fix this
![]() Click image to enlarge I couldn’t find this thread earlier and posted more engine bay photos here, thanks to Martin for pointing me in the right direction to this again https://www.defender2.net/forum/topic87176.html Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
chrispuk Member Since: 22 Nov 2021 Location: Wirral Posts: 13 ![]() ![]() |
Mine has started chafing the outside of the hose so have put a couple stainless hose clips round to protect it from the sharp plastic edge.
The updated part is now available, it's a warranty issue but l ended up buying the part myself
![]() Click image to enlarge ![]() Click image to enlarge |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1464 ![]() ![]() ![]() |
![]() So you buy a brand new Defender, from a UK dealer, then you have to buy parts from them to properly fix engineering defects, while it's still in warranty? In which parallel universe is this a correct and proper course of action? |
Oh l am sure the dealership would have done it, but the vehicle has already been in once for the fault and they only replaced the hose.
When l got the vehicle back it had scratches on the rear panel that looked like they were done by an automatic car wash. It's less hassle for me to just buy the part and fit it myself. l'll toss off an email to Land Rover to see if l can get some money back for the part, but l won't hold my breath. |
