![]() | Home > Puma (Tdci) > Engine oil light - 2.2 2013 puma |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5850 ![]() ![]() |
How soon after the water crossing was the illumination of the light?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2232 ![]() ![]() |
It may have been a temporary short on the oil pressure switch wiring or connector due to water ingress. Oil pressure switches are either normally closed or normally open. I think the puma ones are normally closed ( I would need to check the wiring diagrams to confirm). If normally closed an earth is extended to the engine ECU when their is no or very low oil pressure. When you start the engine oil pressure is generated and a diaphragm in the switch moves and opens the switch contacts, removing the earth. Not seeing the earth means the ECU believes oil pressure is there and extinguishes the oil light on dash.
Therefore if the oil switch wiring is shorted by water ingress an earth is present and the light comes on. This may have happened to you and as the water dissipated the short to earth is removed and the engine light extinguished. So have a look at your oil pressure switch connector to see if it is damp inside and at the wiring to see if it is chafed and close to touching metal components of the vehicle. Edit. Fixed spelling mistake:-) Last edited by Ianh on 12th Mar 2023 2:58pm. Edited 1 time in total |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 223 ![]() ![]() ![]() |
Thanks Ian and Landy Andy
It was soon after the water crossing so I’ll start there and have a look at the switch first. Andy |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3520 ![]() ![]() ![]() |
Was it sea water? Sea water is very conductive (and hence so corrosive), which could make an electrical path to ground.
Having said that, the 2.2 oil pump is not the most reliable. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
No definitely not sea water, I keep it well away from driving through that.
