![]() | Home > Tdi > R380 gearbox identification without a serial number |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
not sure if you have had a go at cleaning it up
have tried wire wool after a light sandpaper and a cost of white paint , spray is fine or maybe a chalk pen and then wipe the excess off . doesn't work every time but can pull old numbers up. |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 ![]() ![]() ![]() |
Road chalk is usually quite good at bringing out numbers on engines and other bits. Just rub it over the area where you think a stamped or raised number should be.
It’s just wax so it shouldn’t cause any issues and will just disappear after a while. |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 260 ![]() ![]() |
post up some photos, I should be able to tell externally Dave
It may have been ground off. Reconditioned boxes can be de-serial numbered.
