Home > General & Technical (L663) > Changing from built in nav to Google Maps |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2779 |
Also it looks like the vehicle's SIM card is no longer connected to the internet
l've checked in settings and it's turned on. |
10th Mar 2023 10:54am |
Solved it!
Reset the pivi pro (held down the power button for 20 seconds) and it's all come back, Google maps re appeared and the SIM is back online |
10th Mar 2023 11:14am |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 |
Good you solved it. If it happens again, on the homescreen in the navigation window there's a button that if you tap it allows you to switch between carplay and built in for nav. https://instagram.com/bentheoandrews
10th Mar 2023 11:40am |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 485 |
Might be obvious, might not.. the quickest way I've found to switch nav source is:
1. Home Screen 2. Little nav source icon (red square) 3. Choose pivi or carplay Click image to enlarge |
11th Mar 2023 3:46pm |
That wouldn't work, l guess the system had crashed.
11th Mar 2023 5:17pm |
You don't see the option if your phone's not connected/doesn't have decent signal for google maps.
20th Mar 2023 12:58pm |
