![]() | Home > Technical > Cam notch and flywheel not aligning |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 537 ![]() ![]() |
Yes as described.
As above. Somehow a tooth out, how did that happen
![]() I fitted the AMC head on to Miffy the summer before last. Excellent quality ![]() |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 ![]() |
Thanks.
I've no idea how it happened. But there was a few signs of bad work from whoever did the job before. Excited to fit the AMC and have it done for good hopefully. Just to be sure, I should lock the flywheel in the slot and not the little dents, is this correct? |
