Home > Maintenance & Modifications > Long standing Td5 resurrection |
peaceman Member Since: 23 Mar 2016 Location: London Posts: 1 |
My Defender TD5 has been standing for at least a year, unfortunately I haven't been able to keep up with regular starts. I'd like to get it fired up again but would like to minimise any damage when I do. It was fully serviced just before its long rest and is in good shape mechanically.
Would greatly appreciate any advice on steps I should run through before doing so? For example; syphon and replace fuel? Replace oil/fluids even if brand new before standing? Is there any risk that cylinders will be dry?! I should mention that it is on a slight incline. If so is there a non-invasive way to lubricate? Cheers! |
2nd Mar 2023 9:57am |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 659 |
Start it in the normal way. Worse case if it doesn’t start, but I very much doubt it - run a purge cycle then start.
2nd Mar 2023 10:42am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2299 |
You could take the injectors out then spin it over on the starter to pump oil around and get oil pressure. Then put them back in and fire it up > 110 XS Double Cab
2nd Mar 2023 10:52am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 816 |
Spin it on the starter with the injectors unplugged for 30 seconds or so. That’ll build up oil pressure and then just fire it up. 12 months isn’t that long. Should be fine IMO. 2008 2.4 110 Utility Station Wagon XS.
2nd Mar 2023 6:02pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
When I picked up out latest 110 Td5 which had been stood for 3years, I took the fan off to gain access to the crank pulley and I put a socket and ratchet on the crank pulley to make sure it hadn't seized.
It hadn't so proceeded to fire it up and it was fine. cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
3rd Mar 2023 11:51am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5697 |
Wouldn’t just unplugging the crank sensor be an easier option? |
3rd Mar 2023 3:21pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
I think by "unplugging the injectors" we are talking about the electrical connection on the front of the engine where the rocker cover internal loom connects with the external loom - not disconnecting the injectors themselves individually 2005 Td5 90 XS
1989 V8 110 CSW |
3rd Mar 2023 4:42pm |
