![]() | Home > Off Topic > Electric chair |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
Given that the seat motors probably draw quite a bit of current, I would go for a separate fused feed from the battery controlled by an ignition switched relay.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Or just get a copy of the wiring diagram from the vehicle you sourced them from and see what cable and fusing was provided originally.
Personally, I would connect to a constant 12V live rather than ignition as it would annoy me having to switch the ignition on every time i might want to move the seat a little. Steve 02' 110 TD5 Double Cab Rebuild Thread |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Thanks for the advice!
LiftedDisco Member Since: 17 Aug 2014 Location: Towcester Posts: 354 ![]() ![]() |
I may have gone for slight overkill but I have a fused permanent 12v supply going to a relay which, in turn, is triggered by a latching switch (one of my spare switches re-purposed to power up the seat circuit).
That way, I can make the seat power live when I need to change the seating position, but the rest of the time it's isolated... |
