Home > Td5 > Crossmember Assembly Rear Floor - Station Wagon
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
Got a quick question regarding the crossmember assembly around the rear floor area. After having sliced off the rear cross member and cleaning up some areas before welding in the new cross member, I noted that the crossmember assembly - rear floor is also a goner and needs to be replaced.
While the process of replacing that piece is going to be another joyful moment in my life, I note that there are two different version of the crossmember. The LR part costs around 300 pounds and the NRC unit costs about 60 pounds.
LR058444
NRC4171
does someone have any experience with both of these and which one to go for?
Thanks
D. Td5 110 Station
Post #984092 1st Mar 2023 8:26pm
Retroanaconda
Neither - buy the one from YRM which is galvanised.
Post #984094 1st Mar 2023 8:48pm
doruk1981
thanks for the tip.
just placed my order with them for the part Td5 110 Station
Post #984098 1st Mar 2023 9:14pm
NineCherries
Scotland 2000 Defender 110 2.5 TD CSW Oslo Blue
as above, id say go with yrm, the brackets bolt on separately making the installation much easier.
Thumbs Up
Post #984263 3rd Mar 2023 10:34am
excossack
YRM. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #984280 3rd Mar 2023 12:18pm
