Home > Puma (Tdci) > 2011 Fob battery change balls-up!
JohnT43
In a triumph of mechanical ineptitude, I swapped out my fob battery this afternoon…easy peasy 🤓👍 Went out to the Landy to try it out….absolutely farq hall happened! Took the fob back indoors to check I hadn’t put the battery in upside down….no that was good, but I’d left the farking sticker on the bottom face of the battery. Took that off, slipped it back into the fob….back outside, still nothing….tried to open the car with the key….you guessed it alarm screaming/immobiliser engaged… Censored 😬 Where to from here chaps??? Thanks in advance for your advice and/or derision 🥸😂👍
Post #984234 2nd Mar 2023 10:32pm
Martin
Site Admin
Try this
https://www.defender2.net/forum/post975932.html#975932  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #984235 2nd Mar 2023 10:35pm
hank
bobs method worked for me recently Thumbs Up > 110 XS Double Cab
Post #984253 3rd Mar 2023 9:10am
JohnT43
Martin wrote:
Try this
That worked a treat! Cheers matey 😃👍👍👍
Post #984600 6th Mar 2023 4:53pm
