Home > Td5 > Steering wheel removal |
I love my Mona-lita wheel. Such a nice feel and classic look. Still looks great after a decade. Just saddle soap the cover from time to time to refresh its supple feel.
25th Oct 2022 11:48am |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 76 |
Before trying to remove your steering wheel you need to have 3 wheatabix for breakfast
25th Oct 2022 3:15pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
My father never kept the nut on when removing steering wheels from his Land Rovers and it never did him any harm. |
25th Oct 2022 4:37pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1875 |
Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
25th Oct 2022 4:50pm |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 |
Well, this job, though not urgent, was one of the most frustrating I have experienced. None of the usual ways of getting the steering wheel off made the slightest impression. No amount of pulling, banging etc. Finally I bit the bullet & purchased the above puller, which did the trick very easily. The wheel is a B type wheel, & is 36 spline. The puller works on the 2 threaded holes visible when you take off the padded centre piece. The threads are 1/4 inch UNF, BTW. Even though these are a fairly late type of wheel, they are not M6, which one would expect. My problem was caused by the clamp bolt for the switchgear coming loose - easily fixed AFTER you get the wheel off!! Thanks to all the members who contributed to this thread. Cheers, Lionel |
9th Nov 2022 11:21am |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 |
Sorry to resurrect a post.
I have a 48 spline wheel off and a 48 spline boss to go on, however, can I for the life of me get it to fit? Absolutely not! Is it usually very tight getting a new boss on? |
23rd Feb 2023 3:10pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 |
does the your original wheel feel tight to fit? you may have been given the wrong boss size or the indicator pins are out too far. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
28th Feb 2023 2:56am |
Is it an Optimill boss, by any chance? I ask because there's at least one case on here where somebody had one that was faulty and wouldn't fit. It was swapped for another, which was then fine.
The splines are tapered so all wheels and bosses should be an easy fit. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
28th Feb 2023 8:12am |
thinman21 Member Since: 27 Jan 2020 Location: Nottingham Posts: 11 |
Shouldn't be tight - it has to be 'snug' (no play between splines and wheel) but should slide on ok. |
28th Feb 2023 8:21am |
Poor manufacturing tolerances then as I suspected. Returned to the seller 🙄
28th Feb 2023 10:30am |
the cheap removeable bosses have been known to fail.
best to spend the extra conkers and buy a decent quality one Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
4th Mar 2023 7:45pm |
It was just a cheapy definitely not optamil, a stopgap solution to a wheel that keeps growing mould.
5th Mar 2023 4:07pm |
