Home > Technical > 2014 Defender 110 running issue |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2100 |
The first question is, why was the battery flat ? Had it been left weeks before starting, had lights or something else been left on ?
I’m just wondering if you have a charging issue, either wiring or alternator. Hence battery not charging and poor running and lights flickering and dash lights up. |
24th Feb 2023 8:27pm |
Jen1v8 Member Since: 18 Feb 2023 Location: London Posts: 7 |
Hello IanH
Thanks for getting back, yes it had been sitting for around 8 weeks |
24th Feb 2023 8:39pm |
I would check how well your battery terminals are clamping, especially the earth clamp. You can loosen, tap down and retighten.
Also fully charge your battery, trickle charging is best. Else you need to go through the battery removal procedure to ensure BBUS alarm does not go off, then remove battery and charge on bench. |
25th Feb 2023 12:32am |
I just bought a new battery and it’s done the trick,
Cheers |
26th Feb 2023 6:05pm |
It did seem to be a power issue, either batt, wiring or alternator. So good you found the problem.
To prevent your starter battery getting so low that it damages it a ctek trickle charger is a good investment. |
26th Feb 2023 6:22pm |
Cheers Ianh
It’s funny how low batteries can cause such strange issues on modern cars Thanks again G |
26th Feb 2023 8:24pm |
