![]() | Home > Maintenance & Modifications > Rear spring question |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
No problem using longer bolts as long as they are not so long as to contact the axle tube on the underside when fully tightened.
From experience the retainer plate needs to be bent at the ends to accommodate even the factory springs. This should happen on its own when you tighten the bolts down. I would not run without the bolts and retainer fully tightened down. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155 ![]() ![]() ![]() |
Hi Steve - I can’t imagine the sort of torque that would be required to bend that solid 4mm plate. I tried with a massive hammer on the edge of my driveway and managed to brake a paved stone lol. I’d be concerned about snapping the bolt head if I used a braker bar to apply the torque you’re talking about…
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3479 ![]() ![]() ![]() |
You can add a few washers between the spring mount and the retainer plate. Those bolts are M10, and can easily bend 4mm plate. I would also rotate the spring just a bit clockwise, so the second coil is not resting so much on the retainer plate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
Please, please excuse me being a bit daft... it's been a long week already... but just going by your first picture, it seems to be the 'rising' coil that's causing the plate to lift at the other end. If you turned the spring a few degrees, so that the retaining plate was just sitting flat on the round spring seat, would that not allow the bolts through more?
It seems to me that this is probably too obvious, and you'll have tried this. As I say, I'm just going by the top pic. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 782 ![]() ![]() ![]() |
I've just taken my rear springs off my 110, and there were two thick-ish washers on each bolt between the retaining plate and the spring seat.
That plate will bend easily if you tighten the bolts, but it will bend at the hole which probably isn't great. |
Good point Dinnu - I originally tried that as this is where the coil was the flattest on the other side. If I go with a long bolt, it won’t be a problem anymore. Re. Torque - I read somewhere the torque for those retainer plate bolt should be set at 40nM… hardly enough to bend those plates unfortunately |
Hi Donald, it is indeed lifting on the other end but when I press it w molegrips against the coil, the bolt is still 7-10mm too short. |
Thanks for the suggestions - I have ran out of day light now. I will try to put more washers in between the plate and the seats tomorrow and use longer bolts.
Just a stupid question in the meantime… am I right in assuming there is no top or bottom end on springs? Both ends seem to have the exact same shape to me Thanks |
The spring will work either way, but if it is a progressive spring (coils are not evenly spaced), the factory used to mount them with the coils closest together on nearer to the chassis. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
An M10 bolt can exert over 3 tons of pressure. I would be surprised is a 4mm flat plate is able to withstand that without bending and/or contouring to shape. The original retainer plate is 3mm, that bends so easily. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Not much torque in my experience. A good hit with my larger uggaddaa gun was more than enough to shape the plate to the required bend when doing them up. The M10 bolt can handle a good doing up in my view*. *note, I am a farmer who views torque specs on some items as mere suggestions and experience of using in rougher situations things suggests sometimes overkill is the best option and thus my views are followed at one's own risk. I look at some of those bolts and think who on earth thinks 40nm will hold that, for instance the brake caliper bolts on my wifes car are only M12 and get 200nm (which I did use the proper thing for). |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 807 ![]() ![]() |
Are they dual rate springs? Otherwise normally no. Not sure about lots of washers. And without wishing to sound rude (easily done on the internet). Doing a bolt up is about as elementary as it gets with mechanics. I'm not really sure I grasp why you are having issues at all.... It is very easy to see what the bolt holds on and where it fits and how much room you have. Not sure if mentioned, you'll want a high tensile nut and bolt, should be stamped 8.8 on the head of the bolt. You could even use a longer bolt just to screw it down and bend the plate, then fit the shorter bolts again. BTW - HD springs might give a harsh ride. |
Thanks all for your input. I should be all set to complete this week end 👍👍
Job done. Thank you all for your advice!
