Home > Puma (Tdci) > Bunny - the great Puma update.
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Well, after seeing so many ongoing blogs, I thought it was time to do my own.
A huge thank you to all contributors and responders to questions for help.
I have done many things to Bunny in the 18+ months I have owned her - lots of security upgrades. New wipers wheel boxes, cable, washer jets, pipes and one way valves. New double din dash and apple car play stereo with USB power plugs. Lots of led dash bulbs. Led footwear lights. Heated seats and mirrors. Drivers seat extended runners. Heater deflector and glove box. Crystal headlamps and long range bulbs with upgraded wiring loom. A frame and steering ball joints. Fuel tank breather pipe renewed. Cb radio and aerial recently added.
This weekend saw the addition of LED body lights, high level brake light- waiting for the led number plate lamp to arrive.
I also very foolishly started replacing all of the brake pads, discs, callipers, swivel seals and other seals this weekend.
Right hand rear pads, discs, callipers replacement went very well. Not so much the left rear - looks like the wheel bearing has over heated at some point so I struggled to remove the hub, leaving the seal and inner bearing in place. Censored . Managed to persuade the bearing off eventually, ordered a new one and shut down for the day.
Photos to follow soon.
[/u]
 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #981420 5th Feb 2023 8:58pm
matchap801
All done. 4 challenging days across a few weeks. I ended up needing left front and rear wheel bearings.
Several test drives later, the brakes are settling in a treat and there are no leaks yet.
The hard work of searching for all the different bits paid off!!!!!
Post #982482 14th Feb 2023 9:38pm
defenderfraggle
Netherlands 2009 Defender 130 Puma 2.4 HCPU Santorini Black
I need to do some dash leds as well. But am having trouble to find the small ones. Do you have partnumbers for all the bulbs?
Post #983113 20th Feb 2023 4:13pm
matchap801
These were for the clock - much better - https://www.ebay.co.uk/itm/191416871350?mk...edia=EMAIL
These were for the dash/heater controls - again much brighter - https://www.ebay.co.uk/itm/261260023574?mk...edia=EMAIL
I hope this helps. Regards. Mat 2009 Defender 90 CSW 2.4 TDCI.
Post #983120 20th Feb 2023 6:07pm
defenderfraggle
Great! Thank you very much.
Post #983132 20th Feb 2023 8:50pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
Nice job!
I really think it's worthwhile documenting your build as so much time and effort goes into the planning and design, let alone the time doing the work. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #983134 20th Feb 2023 8:57pm
matchap801
Indeed. That was four tough days to do the brakes and seals. Costs were more than I had planned - bit it was worth it. Plus all the work I did at the start of ownership.
Completely forgot I had put one pice drive shafts in the rear until I pulled them out! 2009 Defender 90 CSW 2.4 TDCI.
Post #983136 20th Feb 2023 9:08pm
defenderfraggle
[quote="matchap801"]These were for the clock - much better - https://www.ebay.co.uk/itm/191416871350?mk...mp;media=L
I received the lights today, wanted to change them, but when you said click did you mean the speed clock or the time? I tried to change the lights in the speed dash, but could not find any…
Post #986136 19th Mar 2023 11:32pm
matchap801
Hi. I replaced the bulbs in the time clock and also the dash heater controls. I know some have changed the speedo and rev counter bulbs but I haven't. Yet! 2009 Defender 90 CSW 2.4 TDCI.
Post #986259 20th Mar 2023 11:09pm
I take my hat off to you to take that much work on. Thumbs Up
Regards dash LED’s, I did that before but was very disappointed.
At first, they seemed great, brighter, cooler running etc.
Then they started flickering, on and off some went off completely others didn’t.
Some worked fine permanently, others kept flashing, others stopped working.
In the end, I replaced them with standard ones again back to where I started as they actually seemed to last longer than the LED’s.
Mind you if you have good LED’s they might be great but mine were duff.
I was going to replace the clock bulb for LED also, but glad I didn’t as I could see the same happening.
Hope that yours are better than the ones I had.
What drive flanges where you thinking of for the front? WeWillWin🇬🇧🇺🇸
Post #986263 20th Mar 2023 11:29pm
matchap801
I tried two types of LED. The ones with the single wires in the base didn't work well at all. The ones with the printed circuit board style have been excellent.
After a very tough off road weekend on Salisbury Plain I am pleased to say my hard work all paid off.
As for drive flanges - I used a second hand Disco Series 1 solid pair on the back (lots of noise gone) straight swap. As for the fronts, I have stuck with the originals, cleaned greased and refitted with original shims and spacers, all is working
Post #986268 20th Mar 2023 11:54pm
matchap801
Post #986269 20th Mar 2023 11:54pm
defenderfraggle
ah ok, cool. I know how to do those. Will do so this weekend (hopefully). Thanks!
Post #986287 21st Mar 2023 9:21am
