Home > Technical > A favour from someone with 110 4/5door please.. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Morning, just going a dry run install of my rebuilt rear tub and sills/b-pillars onto my new chassis. As i have ended up changing so many parts, i have now lost my reference points unfortunately. I want to try and make sure everything fits before it gets painted though so i can avoid having to modify too much at that point.
What i am struggling with is the interface between the C-pillar and the rear tub sides. Would someone be able to take a few photos of the interface between the C-pillar, tub and rear capping just inside the rear door please? It would be mega helpful if someone could confirm a few dimensions for me too please: 1. Depth of the return which the second row door seal fits onto at the C-Pillar (below the level of the capping). 2. Second row LH Door Aperture size (B-pillar to C-pillar) 3. Second row RH Door Aperture size (B-pillar to C-pillar) Would be very grateful if someone would be willing to help out please? Thanks, Steve 02' 110 TD5 Double Cab Rebuild Thread |
14th Feb 2023 11:30am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
A few more pics
Click image to enlarge Click image to enlarge Click image to enlarge |
14th Feb 2023 2:24pm |
That is absolutely brilliant thankyou
Yours looks to be original too which is even better. Would you just be able to confirm for me that, in your penultimate picture, the front edge of the C-pillar vertical box section is roughly aligned with the edge of the capping? Many Thanks, Steve 02' 110 TD5 Double Cab Rebuild Thread |
14th Feb 2023 4:08pm |
Well...I've just been outside in my bath robe with a torch and the phone. Two things happened - I found out how rusty my tub is getting and I very probably flashed a neighbour (she nearly had a stroke, but I was too quick for her, lol!)
However, I have got a photo which I think shows the detail you want. Click image to enlarge |
14th Feb 2023 8:32pm |
Ideal thankyou!
15th Feb 2023 7:15pm |
