Home > Td5 > 2003 TD5 Rear discs and pads...
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Hi all, does anyone have any recommendations for rear brake kits? Im only looking for standard not performance as its a standard TD5. There seems to be so many options out there with kits offering different componants? What do i need to undertake the job?
please be gentle as I'm still quite new to defender ownership Laughing
Picture of my current discs so you understand why I'm changing
Post #982362 13th Feb 2023 10:28pm
landy andy
This is what you require.
https://lofclutches.com/shop/brakes/brake-...cba1185463
If the rear callipers look even slightly crappy change them. They don’t tend to last well on Defenders in my experience.
These will last longer than standard.
https://lofclutches.com/shop/brakes/brakec...cba1185463
Post #982366 13th Feb 2023 10:42pm
htb2
Wales
Delphi
Post #982370 13th Feb 2023 10:53pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I have a 1993 90 with a 300tdi rear axle, so standard callipers, discs etc.
I changed my calipers and discs for britpart but used quality pads. I did my wheel bearings and seals plus changed my bolts etc.they fitted OK.
I fitted stainless grease nipples but also had to replace the brake pipes as they broke when taking them off, so ended up replacing the rear flex then changing the brake fluid.
So beware of the job creeping further than you originally thought.
Post #982372 13th Feb 2023 11:09pm
2hel
Thanks all! Yes I'm slightly worried about the job escalating so want to make sure I have all the parts I need and just do it once (without spending a fortune ideally)
The calipers don't look too bad but no idea what the pistons are like, I'll get a price with and without the calipers see how much extra it would be
I assume best places are Paddocks or LRParts?
Post #982373 13th Feb 2023 11:12pm
Retroanaconda
You don’t need upgraded parts, standard spec items from a reportable manufacturer (not Britpart…) will be absolutely fine.
Delphi, Mintex, AP Lockheed etc. all will be fine. Advice above re. calipers is sound. It will be worth having some spares of the caliper bolts handy too, and don’t forget the consumables for the wheel bearings etc.
Post #982374 13th Feb 2023 11:16pm
Screbble
100% agree with Mossberg 👍
If you’re going to change the discs, make sure you have new bolts to hand, and be prepared for a fight getting the old ones out. Also do be aware that you’ll have to remove the hub, so again make sure you have the new gaskets, seals etc. to hand.
As already said, also a good time to inspect your wheel bearings and adjust/grease/replace as required.
Your calipers don’t look any worse than mine which work perfectly.
Mintex pads for me and Delphi discs.
Good luck 🤞
Post #982376 13th Feb 2023 11:19pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
New Mintex discs and pads all round just fitted on my 04 Td5. 04' 90 Td5 CSW..
Post #982381 13th Feb 2023 11:44pm
TexasRover
Good luck 🤞
Yeah for the caliper bolts get the right socket 12 point - 13mm I recall (or was it 15) and a long breakerbar ideally with ratchet. Don't mess up that bolt with a crappy tool. Its a little tight for an impact and not too much room to swing a breaker bar either.
I cracked (as in split open) my socket on my range rover (same bolts) and had to wait 48 hours for a new socket to arrive to finish the job. you got to have the right tools
Post #982454 14th Feb 2023 7:22pm
Mossberg
It should be a 12 spline, or bi-hex, socket. Clean the bolts the best you can and then get a good fitting socket. You really don't want to round these off if you can help it.
Make sure you treat the bolts with plusgas for two or three days before you attempt the job. Same goes for the brake pipes and the bleed nipples.
Post #982458 14th Feb 2023 7:48pm
kenzle8a
I bought the full front and rear kit from LOF, just the road spec ones. Its nice as it comes with everything you need to save faffing and ordering a whole list of things. I got the bearings in mine incase I need them, although my ones were fine its nice to have the correct spares.
Its also nice to support a business like LOF who create decent kits and bits for us Landy owners.
Post #982462 14th Feb 2023 8:08pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Also invest in a decent brake pipe spanner as a standard open ended spanner is more likely to round off the brake pipe fittings. Available from all the usual places, something like this -
https://www.halfords.com/tools/hand-tools/...28251.html
Worth getting both sizes as you never know when they'll come in handy
Post #982483 14th Feb 2023 9:43pm
Procta
where did you get the stainless grease nipples? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #982485 14th Feb 2023 9:52pm
Procta
Re: 2003 TD5 Rear discs and pads...
Make sure you have a decent quality socket for those, i found they are 1/2 not 13mm. Some Censored who serviced the brakes on mine, had badly rounded the bolt, so we had to cut the bloody bolt, and then cut the caliper in half, so it would come off the disc. Then it was just a case of grabbing the stud a molegrips. A simple job turned into a nightmare for us!
So stock up on spare parts before you tackle this! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #982486 14th Feb 2023 9:56pm
Mossberg
https://www.ebay.co.uk/itm/333906079138?mk...media=COPY
Post #982506 15th Feb 2023 6:08am
