Home > Td5 > Cold start hesitancy |
Sounds like a bit of air getting into the fuel system when it's being left to stand for a while. Darren
1st Feb 2023 8:57pm |
FD7 Member Since: 16 Feb 2021 Location: Midland Posts: 170 |
Can something be done about that?
1st Feb 2023 9:14pm |
Almost certainly, but the trick is finding where the leak is, unfortunately. One potential culprit is the joints between the pipes and fuel filter housing, which are known to go brittle. Another is corrosion of the pipes into the top of the sender unit in the tank. It could even just be the fuel filter itself not being fitted tightly enough. Darren
1st Feb 2023 9:21pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Before your first start pump the accelerator pedal 10 times with ignition on. This will run the pump in the fuel bleeding mode. The engine light will flash during this. After try and start, if it starts straight away then you have a better idea air was in fuel. Normal with air in the fuel system the pump also becomes noisier.
It could also be that your glow plugs aren’t all working. |
1st Feb 2023 9:31pm |
Thank you both for the responses - all helpful
I haven't used this Landy for just over a week and thought almost certainly I'd need to carry out the purge procedure. However, it cranked over and in a couple seconds fired up. It was approx 7 degrees outside, so indoors imagine a little more. I suppose I can continue to monitor - but how very odd! By the way, is there any ill effects by performing the purge procedure? Also.... is it possible if air was in the system, can it find its way out (for good) if the vehicle is used? (Assuming no leak etc) Last edited by FD7 on 9th Feb 2023 6:39pm. Edited 2 times in total |
9th Feb 2023 6:34pm |
Sounds more like duff, (maybe just afew not all) glow plugs have failed. As standard there are only 4 for the 5 cylinders.
9th Feb 2023 6:36pm |
Hmm, I was thinking what you said too and the Landy is over 100k miles.
I will add a full set of genuine ones to the list and hopefully no concerns upon removal. |
9th Feb 2023 6:41pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 161 |
A good TD5 does not need glow plugs to start.
Not saying mine is good, but it will start when frozen solid as soon as the starter turns, no glow plugs. It will do the same when stood for 2 or 3 weeks. My suggestion would be air getting in somewhere. Is it the same when the fuel tank is full? |
9th Feb 2023 8:40pm |
I notice a difference in mine when using the glow plugs or not when V cold.
9th Feb 2023 9:10pm |
Well…. Touchwood… this is now a non existent problem. It seems to be cold starting whenever I desire, whether it be days or weeks apart.
So none the wiser but not overly concerned anymore. |
24th Feb 2023 1:54pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5172 |
might have be the battery is now fully charged? i know my 306 HDI can struggle like hell to fire over if the battery is on its way out, when cold, even more noticeable if its cold. My TD5 did the same thing when the battery was on its way out, so i suspect your battery could be on its way out, cold weather is a tester for batteries.
So i wouldn't rule the battery out due to the age of it, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
28th Feb 2023 2:52am |
