Home > General & Technical (L663) > Recall on i6 engine |
brucehun Member Since: 04 Dec 2012 Location: Johannesburg Posts: 24 |
Anyone affected by this:
https://www.autoevolution.com/news/jaguar-...09820.html |
6th Feb 2023 10:54am |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 137 |
The problem is, this recall was filed with the NHTSA in the US (pdf attached to article). This means that only NAS vehicles will be covered by this filing and LR does not sell diesel vehicles in the US. The AJ20 P6 and AJ20 D6 share numerous components - I have no idea if the cam carrier is amongst them or not (and I was not able to figure this out on a very quick search just now - no more time). The valve train is different due to the variable valve timing on the petrol models, though.
My car could theoretically fall into the VIN range, but I have a D250. When I was last on Topix about 2 weeks ago nothing but the 2nd key was listed as outstanding. I'll have to check again when I have a min. Thanks for the heads-up. RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
6th Feb 2023 1:24pm |
silent_fury Member Since: 28 Aug 2022 Location: Romania Posts: 23 |
Well, this is a D300 Engine.
Oil leak on passanger side. The post is on FB The New Defender Owners Group. Only 8000K miles. Click image to enlarge |
12th Feb 2023 10:24am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2759 |
l guess owners should keep an eye out for oil leaks then.
12th Feb 2023 5:31pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
“They all do that Sir…”
12th Feb 2023 6:05pm |
Good old Facebook strikes again
Where's this oil leak supposed to come from, once l've cleaned my drive of the oil that leaked out of my old TD5 Defender l'll keep a look out for it. Although on that FB post it sounds like the engine has let go and not just an oil leak. |
12th Feb 2023 7:10pm |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Other countries' authorities will follow with recall information for sure.
It's not unsusal for NHTSA to be much quicker with publishing recalls. |
13th Feb 2023 4:24pm |
